restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
  1. Deleted
  2. Deleted
    2018-08-28T22:16:47+00:00
    I'm trying to locate where my ink levels can be found! The printer works great! I don't know how much ink I have!
    From another post:
    I'm running window 10 with internet explore!
  4. Deleted
