restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2018-01-15T18:07:06+00:00
    Problem solved. Thanks.
  2. Deleted
    2018-01-31T16:47:49+00:00
    I cannot find my printer icon
  4. Don Varnau 19,930 Reputation points Volunteer Moderator
    2018-02-01T15:10:00+00:00
    Ron and BettySmith replied :
    1. Which version of Windows are you running?
    2. Which version of Internet Explorer or other browser?
    3. If running Windows 10, are you using the Edge browser or Internet Explorer?
    Don
