restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2013-01-20T16:02:32+00:00
    [Merged]
    I lost my toolbar, how do I restore it>
    Thank you.
    2013-01-18T19:09:56+00:00
    Hi Donna,
    Right click on an empty space on the tool bar, and select the command bar.
