Can't output sound to bluetooth speaker (JBL flip)
2013-05-22T21:48:22+00:00
Hi there,
I have a JBL flip portable bluetooth speaker which works fine with my smartphone etc.  My laptop (Samsung, windows 7) connects with it and identifies it as a bluetooth headset, however I can't play any music through it at all.  The laptop doesn't recognize it as a "playback device" or a piece of hardware in the "sound" section of the control panel and I can't seem to get it to work at all.
Any ideas anyone?
Many thanks
Mike
2013-05-23T14:40:53+00:00
Hi Michael,
The issue could be caused in the Volume Settings, sound card or driver.
. Did you check the issue with different laptop?
Follow the methods below:
Method 1:
Try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones.
Tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows7/Tips-for-fixing-common-sound-problems
Method 2:
Try installing the drivers and check the status.
Update a driver for hardware that isn't working properly:
http://windows.microsoft.com/en-US/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Method 3:
After you've paired (connected) a Bluetooth enabled device with a Bluetooth enabled computer, you can change the name of the device or enable or disable services for it. You can also control how your computer pairs with this and with other Bluetooth enabled devices.
Change settings for a Bluetooth enabled device:
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
For reference:
Add a Bluetooth or other wireless or network device: frequently asked questions:
http://windows.microsoft.com/en-US/windows7/Add-a-Bluetooth-or-other-wireless-or-network-device-frequently-asked-questions
For more help:
Contact JBL Support:
http://www.jbl.com/estore/jbl/us/support/spdp.jsp?pid=JBL FLIP
Let us know the status of the issue. If you need further assistance, please post back. We will be glad to help you.
44 additional answers
  1. Deleted
    2014-01-02T03:43:01+00:00
    Paired bluetooth speaker (JBL Flip) with HP notebook - pairing OK - device recognized and listed under bluetooth devices, but cannot get sound routed to it.  Troubleshooter says nothing is wrong.  Troubleshooter is wrong.  I want this device to behave the same way my bluetooth headset works - that is, when I turn it on, it connects to the computer and seizes the audio output.
    Why is there no help for this problem???
    2014-02-24T13:55:30+00:00
    I had the same issue. I am using Windows 7 on a Lenovo. When I was trying to pair, Windows would say No driver found or something similar. What I did was to go to Lenovo website and downloaded the latest Bluetooth driver and install it. With a couple tries and a few reboots now the JBL flip 2 works fine with my PC.
    Hope it helps.
    PT.
    2014-02-25T00:23:11+00:00
    Hi everybody, i had the same problem.
    What i did was: after pairing the device i rebooted the laptop.
    then i went to Panel Control -----> Hardware & Sound ------> Admin. Audio Devices (i dont know if in inglish is this right, in spanish it si "Administrar dispositivos de audio).
    if you see the headphones bluetooth audio make right click and go to "properties" ---> General, and down there you must select where it says "device use" ENABLE
    i got the spanish version, so hope you can undertand what i did.
    hope to be helpfull.
    See ya.
