USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2013-01-06T03:37:20+00:00
    Click Here
    2013-01-06T04:53:11+00:00
    Change your computer date to Dec 2012...Delete your printer, then refresh your computer again.  After refreshing it...see if you can add your printer back and have it work.  Create restore points as you make each change...incase things do not work for you.  If everything is good...correct the date.  Worked for me on my Toshiba Satellite P875-S7310.  Really starting to regret this Windows 8!
  3. Deleted
    2013-01-06T19:24:56+00:00
    Me too - none of the suggestions work - tried HP site and Intel. Frankly I don't see why I should even have to try. MS , Intel and HP should get their act together. About to return Laptop..........
