USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2013-05-13T04:34:33+00:00
    WHAT IF THIS IS WHAT I GET AS ANSWERS FROM INTEL?
    An Intel device was detected but your operating system is not supported by this utility. Please visit Download Center to look for available software.
    2013-06-21T16:27:30+00:00
    I found the problem it is with the Intel® Wireless Display Software that can be found at this link http://www.intel.com/p/en\_US/support/detect?wapkw=intel+driver+update+utility+
    2013-07-20T11:40:23+00:00
    ¡ Perfecto ! Muchas gracias.......
    Me ha servido de ayuda y he podido arreglar el problema.
    Ya estaba medio loco... y siguiendo los pasos todo Ok.
    Gracias..
    2013-07-30T03:07:51+00:00
    I am looking for a solution, also. I am having problems with the DVD drive, on the same model computer. Thanks to HP Support, I have already replaced it once, but to no avail. It works once and then dies. This does sound like a Microsoft problem, not an HP or Sony or .....
