USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2013-04-05T15:44:23+00:00
    Answer:- well i too faced this problem in my Dell Inspiron Laptop when  iupgraded from win 7 to win8
    The best way to solve is go to browser& type in the address bar:-
    http://www.downloadcenter.intel.com----->Support--->
    or use the  "Inel Driver update utility"---->continue------->check your system for updated drivers
    Note:- sometimesthis scanning utility could not identify your problem
    at that time from the results displayed after scanning---->
    Select the Intel Wireless Display software-->click on  update driver -->loading--->Agree & free download of java if not preinstalledin the system--->
    After download you can find ur file in c:/Downloads/Software/Setup 3.5.4.0.execlick next --> i agree--finish
    Now check ifproblem persist by going in My Computer-->Right click properties-->Device manager-->if still any yellow or red mark before driver then problem persist if no symbol mark then everything is fine
    You c instal the Intel centrino @ wireless N_1030 driver after  the above driver installation bcause it updates thesoftware & completely returns to a working states
    yours friendly advicer PriyeshBatra
    2013-04-19T23:02:23+00:00
    benim toshiba p855 de de aynı sorun var yardım
    2013-04-28T12:55:48+00:00
    I have HP Envy-6 notebook with windows 8 and the same problem - USB-IF xCHI USB host controller is not working properly.
    I updated driver for Intel Wireless Display from Intel web site. And the problem was solved completely. Use this link, click Check your system for the latest updates
    http://www.intel.com/p/en_US/support/detect/wireless-display
    Or use the download center to find the latest driver
    https://downloadcenter.intel.com/default.aspx
    2013-05-05T00:59:46+00:00
    Intel® Wireless Display <br> --- <br><br><br><br><br> Yellow Exclamation Mark for USB-IF xHCI USB Host Controller Intel WiUSB <br> ---
    Symptom:  <br><br>A yellow exclamation mark displays in Device Manager for the device labeled USB-IF xHCI USB Host Controller intel WiUSB. This issue impacts systems running Intel® Wireless Display, or Intel® WiDi.<br><br><br>Resolution: <br><br>Install WiDi software version 3.5 or higher. See the Intel® Driver Update Utility for WiDi to download the latest version.
