USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2013-03-23T12:49:48+00:00
    Same thing on my HP envy15.  My troubleshooter says the most current drivers are installed, but the Device Manager says "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)."  Please help!
    AYNI SORUN BENDE DE VAR NE YAPMAM GEREKİYOR LÜTFEN YARDIN EDIN,  TURKISH WRITE
    2013-03-29T22:21:19+00:00
    yo lo solucione con esta actualización
    se llama Intel Wireless Display Connection Manager:
    instálalo y listo
    http://www.dell.com/support/drivers/mx/es/mxdhs1/DriverDetails/Product/inspiron-15r-5520?driverId=6TF04&osCode=W764&fileId=2991137355&languageCode=es
    2013-04-02T20:37:10+00:00
    Go to the Intel website and use their system update tool.
    http://www.intel.com/p/en_US/support/detect/wireless-display
    It will recommend the upgrades to USB-IF xHCI USB host controller.... I have a new HP ENVY dv7 and I used the tool, updated the two recommended  upgrades and no more exclamation point in the Device Manager.
    Try it...
    2013-04-03T02:06:33+00:00
    I followed your instructions and I no longer have a yellow exclamation point in the Device Manager.  Now I need to see if this prevents the random loss of the WiFi signal on my laptop.  Thank you.
