ok so the computer is a windows 10 and the tv is a new sharp 4k hud tv both are hooked up to the same network
how do i connect laptop to smart tv using wi-fi..?? Any application related to it.??
want to stream laptop on to a tv screen using wifi...?
2019-03-16T01:38:40+00:00 -
2019-03-16T14:08:27+00:00 Yes, both TV and computer are paired and still did not work...both are wireless in the same network.
Thanks.
2019-04-01T22:37:46+00:00 can't connect tv with pc through wireless
**1.**Is the TV Digital Living Network Alliance (DLNA) enabled?
yes
**2.**What is the make and modele of the TV and the laptop?
surface pro4 and ssnyo smart tv
**3.**Are both the devices connecteds to the modem?
yes
**4.**Do you have Windows Media Center installed on the computer?
no
**5.**Are you able to connect the laptop and the TV using an HDMI cable?
yes
