Blue screen issue with error codes 0xc0000098 and 0xc0000102
2013-01-20T11:45:51+00:00
Original title: windows 8 error
I have installed windows 8 on my desktop computer and it is working perfectly some days ago. but now when i start computer i receive the error with the blue screen in windows 8. Error is
Recovery
You PC couldn't start properly
the application or operating system couldn't be loaded because a required file is missing or contains errors.
File :\windows\system32\winload.exe
Error code: 0xc0000098
Below on same page two options were given
Press enter to try again
Press F8 for startup Settings
after clicking anyone of them various option appears but when clicking any option like enable debugging...
Blue screen appears where error:0xc0000102
Again and again this process goes on. I haven't face such a problem before in my life using windows.
One more thing windows setup was also not coming after using both USB and dvd.
kindly do something
2013-02-11T21:06:20+00:00
I had the same exact issue... Try inserting the windows 8 installation disc or OEM disc that came with ur pc. this is what worked for me
For Windows 8:
1 – Boot from repair disc > Choose Keyboard type > click Troubleshoot > click Advanced options > choose Automatic Repair
if that fails then use:
2 -Boot from Recovery disc or Install disc
-Boot from repair disc > Chose Keyboard type > click Troubleshoot > click Advanced options > choose Command Prompt
or
-Boot from Install disc > Click Next > click Repair your computer > click Troubleshoot > click Advanced options > choose Command Prompt
type > bootrec /fixmbr press Enter(writes mbr but does not overwrite partition table)
type > bootrec /fixboot press Enter(writes new boot sector to system partition)
type > bootrec /rebuildbcd press Enter(scans for other OS’s, unlike rebuildbcd it allows you to select the OS’s you want to add to bcd)
after you have entered these commands, close the Command Prompt and Reboot your PC
43 additional answers
    2013-02-07T05:36:11+00:00
  2. Deleted
    2013-02-07T14:30:36+00:00
    To AngelSalguero - ditto, on the phone with Dell for hours, they finally agreed to replace my hard drive and a technician was dispatched.  Of course, now I have to start all over to set up the computer as I had it!
    To Linney - I don't know about AngelSalguero, but those solutions you link to won't work for me...I can't even get to the Windows boot manager to attempt the system repair.  I couldn't even get the system to boot from a bootable CD with windows OS on it!
    To both - my system was also brand new (December 2012) with windows 8....seems like Dell and Microsoft need to figure out what's going on here.
    2013-02-07T20:04:47+00:00
    It sounds like it is too late to look at this idea but could, or can you, get into the Bios, and if so, are the hard drives recognised in there?
    Here are some articles put out by Dell about booting problems.
    Windows 8 Emerging Issues
    http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=587921
    Computer Will Not Boot to Microsoft Windows 8
    http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=584333
    Windows 8 STOP Error (Blue Screen) Troubleshooting
    http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=584512
    http://www.google.com.au/search?q=dell+windows+8+booting+problem&sourceid=ie7&rls=com.microsoft:en-AU:IE-Address&ie=&oe=&redir_esc=&ei=PQkUUdD6CoWZiQeep4HYAw
