These are related to your athw8x.sys (atheros wifi driver) and a incomplete install of Avira. I would re-install the newest driver and remove Avira and use the built in Defender
Error : DRIVER_IRQL_NOT_LESS_OR_EQUAL(athw8x.sys)
A few minutes ago an error began to occur. this is the error: DRIVER_IRQL_NOT_LESS_OR_EQUAL(athw8x.sys). I need some help ASAP. By the way, i copied the contents of minidump and the MSinfo32....
https://skydrive.live.com/redir?resid=A01CF95B29BA05BF!167&authkey=!APOk5UklE9zq7Bw
https://skydrive.live.com/redir?resid=A01CF95B29BA05BF!176&authkey=!ADsSgtxReSDUN54 . Please, what can i do to avoid this error? .... Thank u
2013-04-14T19:03:47+00:00 -
2013-04-14T19:10:14+00:00 In your case these are related to your athw8x.sys (atheros wifi driver) and Symantec. I would re-install the newest driver available and remove Symantec and use the built in Defender.Old drivers needing updating
tosrfec.sys 7/12/2011 7:05:25 AM
Ironx64.SYS 5/23/2012 1:14:39 PM
athw8x.sys 6/14/2012 5:41:08 AM
tos_sps64.sys 6/17/2012 9:21:30 PM
CHDRT64.sys 6/26/2012 10:08:29 PM
HECIx64.sys 7/2/2012 6:14:58 PM
L1C63x64.sys 7/6/2012 1:38:21 AM
AtihdW86.sys 7/17/2012 3:34:09 AM
How To Find Drivers:
****- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program
The most common drivers are listed on this page: Driver Reference
http://www.carrona.org/dvrref.php
- Driver manufacturer links are on this page: http://www.carrona.org
2013-04-15T12:35:54+00:00 Hello,
I got exactly the same problem "DRIVER_IRQL_NOT_LESS_OR_EQUAL_(athw8x.sys)"
with my brand new TOSHIBA SATELLITE L855 win8
I went back to the shop to change the same laptop but still got the same problem!
If I cant fix it on my own I will have to buy an another brand and model
Here is my skydrive file:
Please help , Thanks
2013-04-16T02:16:20+00:00 Might be better if everyone started their own thread. It is getting far to confusing at this point.
2013-04-22T12:46:16+00:00 Hi, I created my own post! Here it is.
Can you help me?
