How can I retrieve/reinstall programs from "Removed Apps" List?
2012-12-30T00:52:40+00:00
Initial problems with installing MS Windows 8  prompted me to refresh my PC, as a result, most programs ended up in a "Removed Apps" List of which I cannot determine on how to reinstall, can anybody help me???
Programs such as HP Support Assistant, and Cyber Link Power DVD, and Windows Media Player are disabled although the troubleshooter states that the Windows Media Player is working properly. Again, please help.
Windows for home | Previous Windows versions | Microsoft Store
    2016-02-09T13:50:07+00:00
    I had to restore my laptop after the windows 10 load because of ongoing problems.  Today I see a list of removed apps three having to do with my Sophos virus protection.  My icon is not showing up and know I do not know if I have it on or not or how to reinstall it from that list of removed apps since it does show up there
    2016-02-16T00:25:40+00:00
    How do I restore Apps that was removed while refreshing my computer?
  3. Deleted
    2016-04-03T20:57:45+00:00
    Several have asked the same question, can someone please provide an answer !!
    2016-04-26T22:35:04+00:00
    good something
     I have stumbled into the same probs as the above on a friends PC, ALL APPS were removed and ALSO HIS/HERS RESTORE POINT !! AND I know it was there as I did their last rinse and restore settings, and as I am NOT a WinBLOWS admirer it helps when you people do actually answer with a FULL response, not hints and suggestions
     Sponge Bob
