"Connect Automatically" box is checked for all the networks in range
2013-08-23T03:59:16+00:00
Original Title: Why can't I prevent Windows 8 from automatically trying to connect to ALL networks in range?
I just purchased a new HP laptop with Windows 8, and this is my 1st experience with Win 8.
I have noticed that when I view the Network List of all networks within range, all of them have the "Connect Automatically" box ticked. I only wish to attempt to connect automatically to my own network. If I un-tick this box for all other networks it makes no difference -- when I look at it again, the box is ticked.
After researching this on the internet I found some advice which suggested right-clicking on the name of the network and selecting "Forget this network" from the menu that pops up. However, right-clicking on the name of any network other than my own does nothing -- no menu appears. If I right-click on the name of my own network this menu DOES appear ("Show estimated usage, Set as metered connection, Forget this network," etc.)
I have read a similar question posted here, as well as the answers given. It did not help. Stopping and starting the WLAN Autoconfig Services makes no difference:
http://answers.microsoft.com/en-us/windows/forum/windows\_8-networking/networks-pane-the-connect-automatically-checkbox/ae5c77fb-1234-4d5b-bf77-628f8b902a7d
It does not appear to me that this person got his/her question resolved adequately, and it seems I have the same concern.
Why is Win 8 configured to connect automatically to ALL networks on the list of available networks, and why am I unable to un-check the "Connect Automatically" box for networks I do not wish to automatically try to connect to? To clarify, I can un-check the box, but the change does not persist; if I move my mouse away from that network name, and then click on it again, "Connect Automatically" is checked again, regardless of the fact that I have just un-checked it.
And why can't I right-click on networks other than my own to access the menu choices which include "forget this network?"
I am a VERY frustrated Windows 8 user. I am about to wipe this stupid hard drive clean and install Linux instead. :(
    2016-09-09T04:39:59+00:00
    Hi Loreto Osa,
    It's 05:03am and I am writing Powershell scripts and came across your post by accident.  I can't believe that you have been left hanging for a solution for 3 years. I'm so sorry that I never saw your post before or the other Windows users.
    I am a high level self-taught Operating Systems support consultant and digital network engineer and fully versed in Cisco, Windows, Linux protocols, applications, kernels, CLI interfaces and a host of other digital eco-system tec products.
    It is absolutely unacceptable that users concerns are not addressed: Please follow to the letter the following:
    1. Now we are going to get YOU to deal directly with your machines NETWORK SHELL and not with pretty Graphical user interfaces which have no power over your issue. We are going to direct NETSH to terminate these offending profiles SSID's which are broadcast as Microwave signals (radio). We are going to get NETSH to block at HARDWARE LEVEL your network card identifying and accepting these signals as connectable profiles.
    2. CLICK ON YOUR WIFI ICON AND WRITE DOWN EVERY SINGLE PROFILE THAT IS PEEING YOU OFF (MAKE SURE IT IS TO THE LETTER - EXACTLY AS DISPLAYED - CAPITALS AND LOWERCASE).
    3. Right-click 'START' and choose 'Command Prompt(Admin). You need admin privilege level.
    4. type the following to block these profiles from your hardware:
    netsh wlan add filter permission=block ssid="WLAN name" networktype=infrastructure
    Type the name of the first profile on your list exactly as it was displayed on your screen between the speech marks. NETSH has now blocked this profile/profiles. Now we are going to direct NETSH not to display them (blocking and displaying are 2 different issues but you have to block first before you can stop their display because NETSH can only stop displaying blocked profiles). To stop displaying blocked profiles type:
    netsh wlan set blockednetworks display=hide
    You can do the above one at a time for each profile name or you can block them all first then enter the stop display command. Personally I like to do things one at a time.
    Also, you will see different ones popping up. They are:
    1.  Cars going past your house/flat/apartment and the people's phones in their cars broadcasting their SSID profiles (these will disappear just as quick after about 150 feet).
    2.  Your furthest away neighbors whose SSID's weak single hits your network card. Just quickly right down these profiles and block and stop display.
    Now your network connections panel will be gloriously empty except for your one (if you want to remove a particular profile from blocked list
    netsh wlan delete filter permission=block ssid="WLAN name" networktype=infrastructure
    And if, for whatever reason, you want to re-display the blocked connections (which I am sure you don't) just add "show" instead of "hide".
    I know the solutions to all the forums problems but when I post solutions and people claim credit for it it kinda hurts, especially as I spend hours into the early mornings teaching myself.
    All the best.
    2016-09-09T09:34:57+00:00
    So is this where we left off....No Solution? I have Windows 7 with same issue. I thinks the whole world does.
    Hi JB,
    Please see my latest reply (09.09.2016) to Loreto to fix this issue for you.
    All the best.
    2016-09-09T09:37:46+00:00
    I have exactly the same PROBLEM........HOW DO YOU STOP EVERY NETWORK WITHIN RANGE FROM HAVING CONNECT AUTOMATICALLY CHECKED.  I will add that this was not always like this...when we bought the computer in May the only Connect Automatically that was checked was the one we checked. This started with one of the Microsoft updates within the last 2 weeks. It is a real pain when the network you're working from drops out and all of a sudden you're connected to a different network.  Quite frankly this sucks and should be taken care of.
    Hi Frank,
    Please see my reply to Loreto dated (09.09.2016) to fix this issue for you.
    All the best.
    2016-09-09T09:39:21+00:00
    I have also been having this issue since upgrading to Windows 8.1 Pro
    I have an Intel Centrino 6205 Wifi Card in a Lenovo X1 Carbon
    All networks are shown as connect automatically, so I go into coffee shops and it just starts connecting to the unsecured WiFi networks there !!
    I have removed all the wifi profiles from the command line using netsh and it still auto connects and still has a tick next to all the wireless networks to connect automatically.
    I hope Microsoft are aware of this as it is most annoying and quite a big bug.
    I can't say I noticed it until I upgraded to 8.1 Pro (via Windows Store)
    Hi DangerMouse,
    Please see my response to Loreto dated 09.09.2016.
    All the best.
    2016-09-09T09:41:02+00:00
    Yes, Mine too!  I believe Microsoft is trying their best not to Help Windows 8 preferred users, every problem I have since removing 8.1 and after updates have not been resolved by Microsoft.  I am not much on conspiracy but this might be one, Microsoft attempting to force us to use 8.1.  I won't give up without a fight!  If I have to go back to wired Internet, I will!
    Hi Sandra,
    Please see my re;sponse to Loreto dated 09.09.2016.
    All the best.
