2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2018-09-27T12:59:04+00:00
    I had the same problem and spoke with  Microsoft Support. So, go to 1) “Control Panel”, then go to 2) “Ease of Use” then 3) then to  “quick access to…, 4) then turn off the tic mark on “Always scan this sect…. “  Originally posted 3/22/18 and it should still be there
    Let’s try, press windows logo, type “narrator settings”, then switch to off position in the first row.
    Have a nice days,
    suwat u.(Thailand)
    27 sep 2018
