2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2018-04-10T00:56:42+00:00
    Some solutions posted here seem to work for Windows 10 Home (my version), others work for Pro.  I posted my fix a couple of weeks ago.  Hope it helps you- see below
     Solution 1) from Settings, type "narrator" into search window  ("narrator" was not on menu I was looking at).  "Switch narrator on or off" then pops up, select "off". Simple. Quick. Thank you. Here's a different solution in case the previous one doesn't work for you. (2) I had gone to Windows Support and they led me to control panel, then ease of use, quick access, and then turn off "always scan this section".  Good luck, an incredibly annoying "feature" .
    KeninMcLean
    Dear KeninMaLean
    Thank you so much for your detail explanation. If we hit “Ctrl+Esc”
    , blue line will disappear, but if you turn off and turn on, you might see blue line again, so we should find “Narrator setting” eg. search in search box, and switch Narrator to “OFF” position.
    have a nice days,
    suwat u.(Thailand)
    10 Apr 2018
