thank you'
Janelle
It worked for me.
I then press Esc.
Exiting Narrator
+Enter.
and
Volume Up button together.i had to press caps lock & esc 3 times nothing will appear until around 5 mins then i tried it worked without indication that the boxes were gone! i hope you find this usful with windows 8!!
This post has already aged and an answer was provided. I highly suggest that you create a new thread and kindly put the right tagging and the information needed for us to assist you better.
Regards.
