2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2017-01-17T01:33:33+00:00
    I have red a on sound icon. Cannot get sound.  Hover over icon, it says no audio output device is installed
    This happened randomly.
    Went to asus  website to download athe driver. Still no sound.
    Can anyone help
    Have Asus Www pc
