2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2016-02-12T22:12:45+00:00
    Many thanks for your interest and am glad to advise that following advice received after my post, I have managed to get rid of the blue line!  So am grateful for the advice I received.
    Hope your queries are answered for you too.
     Regards,
    Michele
