thank you'
Janelle
It worked for me.
I then press Esc.
Exiting Narrator
+Enter.
and
Volume Up button together.i had to press caps lock & esc 3 times nothing will appear until around 5 mins then i tried it worked without indication that the boxes were gone! i hope you find this usful with windows 8!!
I have a desktop PC maybe the problem fix for lap tops is different, wish I could help. Hope you can find a solution soon.
