2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2013-03-01T17:15:36+00:00
    Thank you, I have been trying to figure this out for three days!!!!
