2013-01-23T23:42:30+00:00
thank you'
Janelle
2013-02-09T00:01:39+00:00
2015-02-03T09:14:46+00:00
It worked for me.
I then press Esc.
2015-02-11T20:26:28+00:00
Exiting Narrator
2015-04-15T23:24:40+00:00
116 additional answers
    2015-08-20T17:29:01+00:00
    Cap Lock / ESC did not work for me (I'm using a MacBook and Parallels to run Windows 8).  I found this on another website.  Basically, look at the bottom of your screen for a new icon for Narrator; click and close it.
    https://yoo2080.wordpress.com/2014/03/09/when-blue-rectangle-border-appears-on-windows-8/
