thank you'
Janelle
It worked for me.
I then press Esc.
Exiting Narrator
+Enter.
and
Volume Up button together.i had to press caps lock & esc 3 times nothing will appear until around 5 mins then i tried it worked without indication that the boxes were gone! i hope you find this usful with windows 8!!
Hi Janelle,
Thank you for posting your query in Microsoft community forums.
I understand that you get a blue box, whenever you type or write in an application.
I suggest you to answer the questions given below.
1) What is the make and model of your computer?
2) Do you remember making any changes to the computer prior to this issue?
3) Is the issue specific to some applications or all the applications?
4) Have you updated your graphic card for Windows 8?
I would suggest you to post a screen shot of the issue that you are facing to help you better.
Refer to the link given below on how to post a screen shot.
Take a screen capture (print your screen):
http://windows.microsoft.com/en-US/windows7/Take-a-screen-capture-print-your-screen
How do I: Post a screen shot on this forum.
Please provide the required information to assist you better.
