Yes.. the cause of that problem is softonic.. i've uninstalled it n it work
how do i fix cef errors
I am getting a pop up indicating there is a cef error and I should get an app from the app store. on checking the app store I got a message indicating there isn't any app available for this.
Deepak
<Removed PII>
2015-04-19T03:04:16+00:00 -
2015-12-18T11:03:52+00:00 True and Effective:
If you have softonic program installed, uninstall it then restart your pc. This will fix it after you restart your pc. Enjoy! ^_^
