ok am doing that to see if this anoying pop up will go away...
how do i fix cef errors
I am getting a pop up indicating there is a cef error and I should get an app from the app store. on checking the app store I got a message indicating there isn't any app available for this.
Deepak
<Removed PII>
2013-11-06T14:30:18+00:00 -
2013-11-13T05:45:40+00:00 i have uninstall softonic let see what happens
2013-12-01T07:30:11+00:00 i've had the same problem.. it keeps on appearing every minute that it gets annoying..
i did all the methods written above but nothing works for me..
but i've tried to uninstall some software.. and IT WORKED..
i have installed a softonic on my laptop and when i removed it/ uninstalled it..
THE PROBLEM WAS FIXED. THE CEF-ERROR DOESN'T APPEAR ANY MORE..
i hope this helps..
Wow......thank you so much for providing this solution.... I have done the same....it worked for me....
2013-12-16T08:35:40+00:00 Thanx for sharing the solutions..It worked in my case..
2013-12-31T18:33:13+00:00 if you have installed softonic in your pc, uninstall it , restart your computer and check.
I sure your problem will be solved.
