Qualcomm Atheros AR9485WB-EG wireless network adapter and windows 8. Wifi connection problems
2013-05-13T21:59:31+00:00
HI, I have an ASUS n56vj with Qualcomm Atheros AR9485WB-EG wireless network adapter and windows 8. It doesnt connect with my home network wi fi, but my other devices work perfectly with it, with perfect sign. Why doesnt this one, what do I do? I have already installed latest version of the drivers provided by asus
2013-05-14T16:25:23+00:00
Hi Daniela,
It looks like there is something in the network which is blocking the device to get connected. So I would suggest you to go through the article and check for the exact issue.
Why can’t I connect to a network?
http://windows.microsoft.com/en-us/windows-8/cant-connect-to-a-network
Why can’t I find a wireless network?
http://windows.microsoft.com/en-us/windows-8/cant-find-wireless-network
If you have any third party software installed on the computer, you can try disabling the anti-virus software and check.
Important Note: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable your antivirus software. If you have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled, your computer is vulnerable to attacks.
Reference:
Wired and wireless network problems
http://windows.microsoft.com/en-IN/windows/network-connection-problem-help#network-problems=windows-8&v1h=win8tab1&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
Do let us know about the results. We would be happy to help you further.
2014-05-26T11:18:28+00:00
Thanks this is a great suggestion for me since I also have a new ASUS computer. For many reasons, removing the ASUS Power4Gear application has helped, WiFi and processor speeds and congestion. The service was always running and activities were constant making those "helpful adjustment" to power settings. Once removed, I just went back to the actual MS pre-programmed power plans.
43 additional answers
    2014-01-10T03:45:07+00:00
    I had the same problem  until i changed the setting in the wifi card.  Search device manager and click on network,  then right click qualcomm atherous,  then click properties and go to AdHoc 11n and enable it if it is disabled.  Then reset the wifi and reconnect.  Hope this works for you
    Norm
    2014-01-20T17:35:02+00:00
    Norm
    Thanks Norm:  This fix has proven to be the most useful.  The only remaining issue is that when MS issues an update or patch it resets the WIN8 default settings.  So periodically I have to manually re configure with these changes. I always know when MS has updated because my wifi connection stops working.
    I note the MS folks trying to dissemble when this problem is raised.  It is sad really because until everyone at MS gets on board with really addressing customer issues the company will continue to fail in its attempts to address market needs.  "IF YOU CUSTOMER CANNOT USE YOUR PRODUCT, NO MATTER WHY, THEN YOUR PRODUCT IS BROKEN!"
    Again Norm, thanks for the fix.
    2014-01-21T16:02:58+00:00
    I changed AdHoc 11n and I found alot more avaible wifi but I still have problem connecting to my home wifi (a Belkin N750DB dualband) after upgrading to win 8.1. Have tested a friends wifi and worked perfect after reseting wifi once. Why dosn't it work with my Belking router?
