Qualcomm Atheros AR9485WB-EG wireless network adapter and windows 8. Wifi connection problems
2013-05-13T21:59:31+00:00
HI, I have an ASUS n56vj with Qualcomm Atheros AR9485WB-EG wireless network adapter and windows 8. It doesnt connect with my home network wi fi, but my other devices work perfectly with it, with perfect sign. Why doesnt this one, what do I do? I have already installed latest version of the drivers provided by asus
2013-05-14T16:25:23+00:00
Hi Daniela,
It looks like there is something in the network which is blocking the device to get connected. So I would suggest you to go through the article and check for the exact issue.
Why can’t I connect to a network?
http://windows.microsoft.com/en-us/windows-8/cant-connect-to-a-network
Why can’t I find a wireless network?
http://windows.microsoft.com/en-us/windows-8/cant-find-wireless-network
If you have any third party software installed on the computer, you can try disabling the anti-virus software and check.
Important Note: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable your antivirus software. If you have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled, your computer is vulnerable to attacks.
Reference:
Wired and wireless network problems
http://windows.microsoft.com/en-IN/windows/network-connection-problem-help#network-problems=windows-8&v1h=win8tab1&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
Do let us know about the results. We would be happy to help you further.
2014-05-26T11:18:28+00:00
Thanks this is a great suggestion for me since I also have a new ASUS computer. For many reasons, removing the ASUS Power4Gear application has helped, WiFi and processor speeds and congestion. The service was always running and activities were constant making those "helpful adjustment" to power settings. Once removed, I just went back to the actual MS pre-programmed power plans.
43 additional answers
    2014-06-24T16:48:03+00:00
    I've had network issues with two laptops with the same network adapter while everything else on the network with different operating systems and portable devices have no problems.
    I put a power line wifi extender in the network and when i tried to join it it said limited but no other devices had any issues with it
    2014-08-28T22:05:40+00:00
    I have the same problem I purchased a netcomm NB16DG modem router and I thought I would never get it to consistently connect to my router wifi..
    2014-08-28T22:14:55+00:00
    I had this problem with a new modem router I purchased. Thought I would never get consistent wifi connectivity.  Finally I downloaded inSSIDer Home SSID scan free. This showed all the local wifi networks in my immediate area and I was able to choose one that gave the minimum overlap and interference at the times I wanted to use my PC. Tt was then a simple matter to select router channels to suit.  This scan also gave a quality rating for each channel you selected, and for other channels in your area.
