Error code 2343 message when trying to repair/remove iCloud 2.1.1.3...
2013-04-14T06:34:47+00:00
I am trying to remove iCloud 2.1.1.3 and I get an error message "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2343." After I click "OK", it gives me the message "Fatal error during installation." How do I fix the error? What to do?
64 additional answers
    2015-10-25T11:42:09+00:00
    Dear all,
    after updating my system to win10 i have the same error with iCloud 5.0 installation.
    unfortunately, under Win10 you can not start the fixit programm. No support for Win10.
    Any Idea?
    Best
    Franz
    2015-10-25T18:09:44+00:00
    Fixit reports it is not supported on Windows 10 :(
    2015-10-27T03:49:41+00:00
    mr. fix it is not supported for win10
    2015-10-27T20:49:26+00:00
    It seems that Microsoft 10 doesn't support this Fixit! Do you confirm?
