Error code 2343 message when trying to repair/remove iCloud 2.1.1.3...
2013-04-14T06:34:47+00:00
I am trying to remove iCloud 2.1.1.3 and I get an error message "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2343." After I click "OK", it gives me the message "Fatal error during installation." How do I fix the error? What to do?
64 additional answers
    2013-09-13T11:13:08+00:00
    So, after waiting for the fixit program to finish his work (over 45 minutes!), all that it has done is remove the unistaller from the Programs and Features control panel option, but the software is still there!!!
    Now I can't even re-install it to try to get rid of it. It gives me another error!
    Help is appreciated! Thanks!
    2013-09-14T03:38:32+00:00
    Finally fixed it by downloading standalone installer from apple. Intalled ok, and then uninstalled ok!
    Thanks!
  3. Deleted
    2014-01-03T09:42:01+00:00
    I am currently doing that this moment but it has been downloading or fixing for like almost 4-5 hours now. I don't know how long it is suppose to take. Do I cancel and restart it again?
