Error code 2343 message when trying to repair/remove iCloud 2.1.1.3...
2013-04-14T06:34:47+00:00
I am trying to remove iCloud 2.1.1.3 and I get an error message "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2343." After I click "OK", it gives me the message "Fatal error during installation." How do I fix the error? What to do?
64 additional answers
    2015-12-10T22:37:55+00:00
    I went to install it and still got the error. The install did get a bit further than it used to
    2015-12-10T23:13:46+00:00
    I went to Apple update and it brought up iCloud for Windows 5.1 so I tried it again and it WORKED.  Looks like later this month has come!!  No more error!!!!!!
    2015-12-11T20:06:48+00:00
    It seems that the problem has been solved, I just updated iCloud Control Panel to version 5.1 and supports Outlook 2016 on Windows 10.
    Yes I did the same and problem solved.  Thanks for that update and information.
    2015-12-12T02:14:26+00:00
    Problem solved because I updated to 5.1.  Whew.
