Error code 2343 message when trying to repair/remove iCloud 2.1.1.3...
2013-04-14T06:34:47+00:00
I am trying to remove iCloud 2.1.1.3 and I get an error message "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2343." After I click "OK", it gives me the message "Fatal error during installation." How do I fix the error? What to do?
64 additional answers
    2013-04-16T11:52:37+00:00
    Hello Devon,
    I would suggest you to run the fixit from the link “Diagnose and fix program installing and uninstalling problems automatically” and then check if this fixes the issue.
    If that doesn’t work then I would suggest you to check with iCloud support for more information.
    http://www.apple.com/support/icloud/
    Thank you Sathish S V - Support Engineer,
    The first link fixed it!
    2013-04-17T09:17:33+00:00
    Hello Devon,
    Glad to know that the issue got resolved. If you have any other issues with Windows in future, please do post it in Microsoft Community. We would be happy to help you.
    2013-04-17T10:12:10+00:00
    Hello Devon,
    2013-08-23T19:42:12+00:00
    Sathish, I have run the "Diagnose and fix..." Mr Fix It.  It has been running for over an hour and still shows the dialog box "Attempting to fix problems with iCloud" and the green progress bar continues to cycle.  I have the slowest DSL connection available as I live in a rural area.  How long should I wait?
