Print Spooler won't start (error 1053) after recent wave of updates to Win7 64-bit
2012-12-14T05:57:12+00:00
Hi, all.
I have exactly the same print spooler symptoms that many seem to have but none of the posted solutions worked.  I think the issues started at the end of November when I let Windows Update install the latest .NET updates and security updates.
Yes. I cleared out the \printers directory (nothing there)
Yes. I ran the SFC /scannow. All verified.
Yes. I checked my dependencies (just RPC and http and both running)
Yes. I checked the event log file. (the canon driver crashed a couple of times but the last time was back in March)
I just finished spending the day doing a "repair install" (re-installed the OS as an upgrade on top of itself).  That fixed the problem and I had my printer back for about 30 mins, but it broke again as Windows Update caught up with the 110 updates that it needed since SP1.
At this point, I'm almost certain one of the windows or .NET updates is causing this.  If anyone could figure out which one it is then I'd just re-install again and skip it.
Any more ideas?
2012-12-29T07:45:18+00:00
Fixing this issue is very simple. Here was what I've done to start the Print Spooler:
  1. Click Start, type “services.msc” and hit Enter.
  2. Scroll down to Print spooler.
  3. Right-click Print spooler, then select Properties.
  4. Select the Log On tab, and uncheck the Allow service to interact with desktop setting.
(Microsoft recommends that you do not change the Allow service to interact with desktop setting. If you allow the service to interact with the desktop, any information that the service displays on the desktop will also be displayed on an interactive user's desktop. A malicious user could then take control of the service or attack it from the interactive desktop).
  1. Once you have uncheck this setting, select the General tab and click "Start" (the Print Spooler should be able to start without popping up the Error 1053 again).
Hope this helps!
78 additional answers
    2014-09-17T18:59:24+00:00
    Select Start, All Programs, Accessories, right click Command Prompt, and click Run as administrator from the drop down menu.. Type *cd* and press ENTER. Type "chkdsk c: /r" without the quotes and hit ENTER. Make sure you include the spaces indicated. Enter Y when asked whether you wish to run chkdsk on restarting the computer. Type exit, press the ENTER key and restart the computer.
    Please run System File Checker and say if it cannot fix corrupted files: http://support.microsoft.com/kb/929833
    2014-09-18T10:00:48+00:00
    Hey bud...I went through each step you listed here - actually 3 times - and still no results....it does not find any problems and I still have the PRINT SPOOLER problem...Any other ideas????? Thanks, Paul
    2014-09-18T10:58:44+00:00
    Select Start, Run, type regedit and press the ENTER key. Check whether the Spooler key is present at the location indicated by the path below.
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Spooler]
    You can expand Computer by clicking the small arrowhead icon to the left of Computer to display HKEY_LOCAL_MACHINE\SYSTEM, repeating each time as you move further down the path.
    The first few lines of the key will contain this information.
    Key Name:          HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Spooler
    Class Name:        <NO CLASS>
    Last Write Time:   15/05/2014 - 17:16
    Value 0
      Type:            REG_SZ
      Data:            @%systemroot%\system32\spoolsv.exe,-1
    Value 1
      Type:            REG_SZ
      Data:            SpoolerGroup
    Value 2
      Type:            REG_EXPAND_SZ
      Data:            %SystemRoot%\System32\spoolsv.exe
    Value 3
      Type:            REG_SZ
      Data:            @%systemroot%\system32\spoolsv.exe,-2
    What do you find?
    2014-09-24T18:46:16+00:00
    I'm having the same problem w/ printer spooler refusing to stay started on Win 7.
    Have tried unchecking "Allow interaction w/ desktop", which worked for maybe a minute.
    Malwarebytes found nothing.  Full chkdsk run.  MSFT Printer Fixit started my Spooler and claimed it was done (altho the spooler stopped mere seconds later).
    I changed my regedit settings to look like yours... the differences were:
      Type:            REG_SZ
      Data:            Print Spooler  <- changed this to match what you have.  no effect
      Type:            REG_EXPAND_SZ
      Data:            C:\WINDOWS\System32\spoolsv.exe  <- this did read as you have above; changed it based on other posts suggesting to specify the exact path; changed it back to match yours and rebooted.  No effect.
    Any other suggestions?  Thanks.
