Print Spooler won't start (error 1053) after recent wave of updates to Win7 64-bit
2012-12-14T05:57:12+00:00
Hi, all.
I have exactly the same print spooler symptoms that many seem to have but none of the posted solutions worked.  I think the issues started at the end of November when I let Windows Update install the latest .NET updates and security updates.
Yes. I cleared out the \printers directory (nothing there)
Yes. I ran the SFC /scannow. All verified.
Yes. I checked my dependencies (just RPC and http and both running)
Yes. I checked the event log file. (the canon driver crashed a couple of times but the last time was back in March)
I just finished spending the day doing a "repair install" (re-installed the OS as an upgrade on top of itself).  That fixed the problem and I had my printer back for about 30 mins, but it broke again as Windows Update caught up with the 110 updates that it needed since SP1.
At this point, I'm almost certain one of the windows or .NET updates is causing this.  If anyone could figure out which one it is then I'd just re-install again and skip it.
Any more ideas?
2012-12-29T07:45:18+00:00
Fixing this issue is very simple. Here was what I've done to start the Print Spooler:
  1. Click Start, type “services.msc” and hit Enter.
  2. Scroll down to Print spooler.
  3. Right-click Print spooler, then select Properties.
  4. Select the Log On tab, and uncheck the Allow service to interact with desktop setting.
(Microsoft recommends that you do not change the Allow service to interact with desktop setting. If you allow the service to interact with the desktop, any information that the service displays on the desktop will also be displayed on an interactive user's desktop. A malicious user could then take control of the service or attack it from the interactive desktop).
  1. Once you have uncheck this setting, select the General tab and click "Start" (the Print Spooler should be able to start without popping up the Error 1053 again).
Hope this helps!
78 additional answers
    2013-02-24T23:10:28+00:00
    Is your printer linked to a single computer or shared by more than one computer? What is your printer make and model? Can you press a button the the printer and print a test page?
    2013-02-25T14:45:24+00:00
    Information was helpful, except you skipped every other step.
    2013-03-01T12:08:38+00:00
    2013-03-05T17:18:11+00:00
    Had same problem. Spent hours messing with this issue. Called Microsoft, NO HELP!! HP, NO help! Hooked up my old Harddrive & printer worked. Computer did an MS update overnite & walla, no spooler start in the morning. Did this trick here & everything is back working fine again!! Hope it stays that way!
    It's Tax time & need my printer working!
