Magic Jack error 3002 How do I fix this problem?
2013-03-08T03:59:08+00:00
I plugged in my new Magic Jack plus into my modem and I started getting this message repeated over and over. ERROR 3002.  Magic Jack said it was a problem with my ISP accepting multiple devices. Can anyone help me with this problem?
2013-03-08T22:34:09+00:00
Hi Robert,
Welcome to Microsoft Community and thanks for posting the question.
As per the description, you get an error code 3002 with Magic Jack.
The issue can be resolved by Rebooting  the Router.
Check the link mentioned below and see if it helps.
**http://www.magicjacksupport.com/a-sulution-for-error-3002-t11548.html**
Hope this information helps.
Reply to us if you face any other Windows Issue, and we would be glad to assist you.
Have a nice day!
2015-05-01T18:42:29+00:00
I have a Q1000 (esetially an Actiontec C1000 with Qwest branding) with the same issue. I reported it as a bug to magicjack. I got mine working with a second dhcp server. I limited the dhcp scope on my Q1000 to 192.168.0.10-192.168.0.20 and have a linux server plugged into the Q1000 on my linux box I have a dhcp server that I added the dhcp scope of 192.168.0.200 - 192.168.0.220 as soon as I activated the scope my magicjack was working.
54 additional answers
    2014-07-01T09:07:26+00:00
    Thank you for your input.
    I hope that your suggestions may help other community members to resolve similar issues.
    I appreciate your efforts.
    Thank you
    2014-07-04T15:58:48+00:00
    I just had this problem, as well.  I have a Motorola NVG589 from Uverse.  The problem was that the status was off in the router.  The simplest solution was to simply unplug the magic jack from the electrical outlet and plug it back in causing my router to recognize it again.
    2014-07-08T10:49:20+00:00
    Hello Cullen,
    Thank you for the valuable input.
    I hope that your suggestions may help other users to resolve similar issues.
    I appreciate your efforts and time.
    Thank you
