Magic Jack error 3002 How do I fix this problem?
2013-03-08T03:59:08+00:00
I plugged in my new Magic Jack plus into my modem and I started getting this message repeated over and over. ERROR 3002.  Magic Jack said it was a problem with my ISP accepting multiple devices. Can anyone help me with this problem?
2013-03-08T22:34:09+00:00
Hi Robert,
Welcome to Microsoft Community and thanks for posting the question.
As per the description, you get an error code 3002 with Magic Jack.
The issue can be resolved by Rebooting  the Router.
Check the link mentioned below and see if it helps.
**http://www.magicjacksupport.com/a-sulution-for-error-3002-t11548.html**
Hope this information helps.
Reply to us if you face any other Windows Issue, and we would be glad to assist you.
Have a nice day!
2015-05-01T18:42:29+00:00
I have a Q1000 (esetially an Actiontec C1000 with Qwest branding) with the same issue. I reported it as a bug to magicjack. I got mine working with a second dhcp server. I limited the dhcp scope on my Q1000 to 192.168.0.10-192.168.0.20 and have a linux server plugged into the Q1000 on my linux box I have a dhcp server that I added the dhcp scope of 192.168.0.200 - 192.168.0.220 as soon as I activated the scope my magicjack was working.
54 additional answers
    2014-05-22T23:01:52+00:00
    2014-06-04T11:46:04+00:00
    Hello Vida,
    Thank you for your response.
    I would suggest you to disable antivirus software and check if it helps.
    Refer:
    Disable antivirus software
    http://windows.microsoft.com/en-us/windows/disable-antivirus-software
    Note: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable your antivirus software. If you have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled, your computer is vulnerable to attacks.
    I hope this information helps.
    Thank you
    2014-06-29T21:41:42+00:00
    Microsoft has NO clue about this error. It has nothing to do with a computer,  isp, a computer, dhcp lease times, mj is just a FLAWED device. Mj will give some bs about something that doesnt matter one bit. What helps could b different for each device. What works for me, is just plughing it into a different port on router. Ive increased dhcp lease to 30 days, etc... wat helps is different port on router, in othrt words, flawed system inside the device. Nothing will fix it
