Try this; maybe it will work:
Control Panel>Mouse>UltraNav>TouchPad Settings>Application Gestures>Edge Swipes>Deselect “Enable Edge Swipes”
I've had a Windows 8 laptop for a few days and the charms bar/settings pages that kept popping up out of nowhere were driving me absolutely insane. BUT, I finally figured out how to turn them off.
I went into control panel>hardware and sound>mouse>device settings>settings. From there you can adjust a lot of the trackpad settings, including DISABLE EDGE SWIPES.
I have a Toshiba Satellite with a synaptics mouse/trackpad, so i cant guarantee this works with all models, devices, etc.
Windows 8 for laptop is now tolerable! Hope this helps!
Thank you this worked. My sanity is returning.
thank you NLMM. i tried to modify the mouse settings to no avail and your method works in charm. thanks a lot. Merry Christmas!!
same here, no open option under my mouse settings or in device mgr. that says trackpad. I have ASUS notebook...
hi, I have an ASUS notebook and there is no Synaptics in my registry. Should I be looking somewhere else?
