How to disable gestures (charms bar, edge swipes, etc...) without changing the registry
2012-12-23T17:49:41+00:00
I've had a Windows 8 laptop for a few days and the charms bar/settings pages that kept popping up out of nowhere were driving me absolutely insane.  BUT, I finally figured out how to turn them off.
I went into control panel>hardware and sound>mouse>device settings>settings.  From there you can adjust a lot of the trackpad settings, including DISABLE EDGE SWIPES.
I have a Toshiba Satellite with a synaptics mouse/trackpad, so i cant guarantee this works with all models, devices, etc.
Windows 8 for laptop is now tolerable!  Hope this helps!
2013-05-23T18:33:46+00:00
Try this; maybe it will work:
Control Panel>Mouse>UltraNav>TouchPad Settings>Application Gestures>Edge Swipes>Deselect “Enable Edge Swipes”
199 additional answers
    2013-12-01T23:27:22+00:00
    This seriously just spared me from throwing my new Lenovo out a window! The charms are beyond irritating. Thanks!
    PS I was having a serious wifi issue until I read on another forum to disable "wmm" in the wireless adapter settings, hope that can help someone else!
    2013-12-07T22:53:17+00:00
    THANK YOU so much for the solution.  It worked perfectly.  What a relief not to have the charms bar popping up all the time.
    2013-12-08T22:40:07+00:00
    It looks like you can't totally disable Charms without going into the Registry. The fixes suggested above won't turn off the bottom right hand corner activation. Luckily, there is a terrific post on techattend.com by Waqas Ahmed -" How to disable Charms Bar in Windows 8.1"- which gives step-by-step instructions, with screen shots, on how to totally disable Charms by adding a line to the Registry. There are no downloads involved so no security issues. I have just worked through it and "Bingo" - Charms is dead.
    Wow!
    2013-12-08T23:01:45+00:00
    I just tried this and it did not work for me!  I HATE THE WINDOWS CHARMS.  HATE, HATE, HATE.
