How to disable gestures (charms bar, edge swipes, etc...) without changing the registry
2012-12-23T17:49:41+00:00
I've had a Windows 8 laptop for a few days and the charms bar/settings pages that kept popping up out of nowhere were driving me absolutely insane.  BUT, I finally figured out how to turn them off.
I went into control panel>hardware and sound>mouse>device settings>settings.  From there you can adjust a lot of the trackpad settings, including DISABLE EDGE SWIPES.
I have a Toshiba Satellite with a synaptics mouse/trackpad, so i cant guarantee this works with all models, devices, etc.
Windows 8 for laptop is now tolerable!  Hope this helps!
2013-05-23T18:33:46+00:00
Try this; maybe it will work:
Control Panel>Mouse>UltraNav>TouchPad Settings>Application Gestures>Edge Swipes>Deselect “Enable Edge Swipes”
199 additional answers
    2013-06-14T14:32:05+00:00
    Can I also say a massive thank you for this link. You saved my sanity!! Can I also say sorry to Microsoft
    as it was a problem of the manufacture's drivers and not Windows 8.
    I bought a Lenovo Iaptop Z580 with Windows 8 four weeks ago. BIG MISTAKE! I can't get rid of this
    (UN)charm(ING) black bar at the side and the popup clock which jumps out frequently and annoyingly
    when I'm trying to get work done. Did Microsoft ever test this heap of junk on consumers before they
    released it? I'll wait till next month, when they release Windows 8.1 (Blue), in the hope that they've actually listened to their customers and fixed these and other issues before I take the OS out.
    If you install the default Windows touchpad drivers. then you don't have the features of the manufacturer's drivers. Which includes swipe. It's the easiest way to get rid of this annoying feature, which is NOT a Windows 8 feature.
    If you have a synaptics touchpad and you don't have these options in the control panel, then you have to install the synaptics drivers.
    http://drivers.synaptics.com/Synaptics_v16_3_15_1_C_XP32_Vista32_Win7-32_XP64_Vista64_Win7-64_Signed_Acme_Inc.zip
    Can i say a massive thank you for this link. I just received my Lenovo z580 (same laptop as the other guy) today and after less than an hour that bar was driving me insane. Anytime I swiped from right to left it would appear and often take me back to Start.
    Not only this but the Lenovo mousepad software seems to be a bit "sticky" and sluggish at the best of times however this link seemed to solve both of these issues.
    Thanks.
    2013-06-19T18:52:15+00:00
    THANK YOU SO MUCH!!!! That right finger swipe was driving me crazy.
    2013-06-21T11:04:07+00:00
    thank you so much for this info! the only one that helped me !!!
    2013-06-21T14:28:34+00:00
    I can't get any of these suggestions to work on a Samsung DP700A3D-A01US PC. I have tried everything from downloading the synaptic drivers (Which I don’t think this PC supports anyways) and also editing the registry. Has anybody used this device and had a similar issue?
