Try this; maybe it will work:
Control Panel>Mouse>UltraNav>TouchPad Settings>Application Gestures>Edge Swipes>Deselect “Enable Edge Swipes”
I've had a Windows 8 laptop for a few days and the charms bar/settings pages that kept popping up out of nowhere were driving me absolutely insane. BUT, I finally figured out how to turn them off.
I went into control panel>hardware and sound>mouse>device settings>settings. From there you can adjust a lot of the trackpad settings, including DISABLE EDGE SWIPES.
I have a Toshiba Satellite with a synaptics mouse/trackpad, so i cant guarantee this works with all models, devices, etc.
Windows 8 for laptop is now tolerable! Hope this helps!
you can still press the windows key on the keyboard which will bring up the apps
THANK YOU! This was driving me crazy! I also downloaded a 'skin' to make it look like my old windows program. But how do I get to all the apps now? Just wondering, although I'm not sure I'll ever need them?
Hi ChrisBorgia,
Thank you for your valuable suggestion; this will help other people to resolve the issue.
For any Windows related assistance in the future, feel free to contact us and we will be glad to help.
