HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2016-06-29T17:22:35+00:00
    Chkdsk/f/r X:C
    any further ideas?
    Try this it works for me well.
    Hope it helps.
    2016-08-14T17:55:03+00:00
    I ran into this problem a couple days ago; this is what I had to do to apparently fix the problem. These directions only apply to people who are able to get into advanced options. To do that just cancel button back till you get the option "advanced options".
    First, you will want to run the chckdsk f/ r/ C:  <--Which ever drive is having the issues. You will enter this from a tab in advanced options called "command prompt". Allow it to completely run through, this may take awhile...
    Second, run the repair option.. it should work this time around. Once it completely runs, you should boot up to sign in or home screen. I have not had any issues since.
    2016-08-15T13:49:41+00:00
    Hello, I'm having exactly the same problem but with windows 10. This is a copy of my SrtTrail.txt, Please can you help!!
    Startup Repair diagnosis and repair log
    Last successful boot time: ‎14/‎08/‎2016 18:05:56 (GMT)
    Number of repair attempts: 6
    Session details
    System Disk = \Device\Harddisk0
    Windows directory = C:\WINDOWS
    AutoChk Run = 0
    Number of root causes = 1
    Test Performed:
    Name: Check for updates
    Result: Completed successfully. Error code =  0x0
    Time taken = 0 ms
    Test Performed:
    Name: System disk test
    Time taken = 0 ms
    Test Performed:
    Name: Disk failure diagnosis
    Time taken = 32 ms
    Test Performed:
    Name: Disk metadata test
    Time taken = 0 ms
    Test Performed:
    Name: Target OS test
    Time taken = 234 ms
    Test Performed:
    Name: Volume content check
    Time taken = 16 ms
    Test Performed:
    Name: Boot manager diagnosis
    Time taken = 1422 ms
    Test Performed:
    Name: System boot log diagnosis
    Time taken = 0 ms
    Test Performed:
    Name: Event log diagnosis
    Time taken = 15 ms
    Test Performed:
    Name: Internal state check
    Time taken = 0 ms
    Test Performed:
    Name: Boot status test
    Time taken = 0 ms
    Test Performed:
    Name: Setup state check
    Time taken = 391 ms
    Test Performed:
    Name: Registry hives test
    Time taken = 2281 ms
    Test Performed:
    Name: Windows boot log diagnosis
    Time taken = 0 ms
    Test Performed:
    Time taken = 438 ms
    Root cause found:
    Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8015880da72, 0xffffd00059646500, 0x0.
    Session details
    AutoChk Run = 0
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 16 ms
    Test Performed:
    Time taken = 234 ms
    Test Performed:
    Time taken = 8453 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 266 ms
    Test Performed:
    Time taken = 62 ms
    Test Performed:
    Time taken = 16 ms
    Test Performed:
    Time taken = 422 ms
    Test Performed:
    Time taken = 2203 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 484 ms
    Root cause found:
    Session details
    AutoChk Run = 0
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 219 ms
    Test Performed:
    Time taken = 7891 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 312 ms
    Test Performed:
    Time taken = 63 ms
    Test Performed:
    Time taken = 47 ms
    Test Performed:
    Time taken = 406 ms
    Test Performed:
    Time taken = 2219 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 468 ms
    Root cause found:
