HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2016-03-24T10:59:00+00:00
    Hi, my family uses an envy 23 and I encountered the SrtTrail problem while switching it on today. I had inserted a cd-r into it at the start of this month for a project and selected use as a hard drive when formatting. I suspect that has something to do with this problem. When I switch it on, it shows a blue screen that says automatic repair and below: automatic repair couldn't repair your PC n allows me to go advanced options. if I press it, it will give me 4 options: continue (exit n continue to Windows 8.1), use a device (use a USB drive, network connection, or Windows recovery DVD), troubleshoot (refresh or reset your PC, or use advanced tools) and turn off your pc. continue puts me in a loop with the pc showing the abv n turn off your pc does not solve the prob as switching it on again puts me in that same loop. use a device gives me a list of devices and a option to see more devices, but clicking on any device will just put me in the same loop as if I had pressed continue. for troubleshoot, refresh doesn't work as they say there was a problem refreshing your pc, No changes were made. Reset your PC is not being considered at the moment as my mum does not want to lose the important stuff she has on the PC. So advanced options is left. There is system restore (use a restore point recorded on your PC to restore Windows), system image recover (recover windows using a specific system image file), startup repair (fix problems that keep windows from loading), command prompt (use the command prompt for advanced troubleshooting, UEFI firmware settings (change settings in your PC's UEFI settings in your PC's UEFI firmware) and startup settings (change windows startup behaviour). all except command prompt I m either not sure about or unable to do. the commands do not work for command prompt as I cant access the folder (srt.srttrail or something liddat). is there anyway to fix this prob without resetting the pc? please reply me ASAP. thank you.
    2016-03-27T22:00:12+00:00
    What do I do if it says "Failed to transfer logged messages to the event log with status 50" ?
    2016-04-06T00:12:48+00:00
    To anyone still having a problem with this error. You need to go to the repair console using the windows disk or built in console. Select troubleshoot, advanced options, startup settings and then restart. Once restarted you will see a list of options. Select the option that refers to "disable driver signature enforcement". Restart the computer and the windows OS will load as normal. Once at your desktop navigate to the folder that was given when you couldn't boot into OS (e.g “C:\Windows\System32\Logfiles\Srt\SrtTrail.txt”) and delete that text file. Restart computer, Problem sorted. I had the same problem and done this on other computers i have repaired and this solved the issues.
    When I restart, it just starts the automatic repair all over again... No screen to press any numbers or anything please help.
    Also, it leads me back to the screen where automatic repair couldn't repair my computer...
