HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2016-02-24T07:03:29+00:00
    Stupid diagnosis repair rubbish, years on windows 7 no problems less than a year on windows 10, shafted!
    2016-03-01T04:11:13+00:00
    I have the same problem. At first it was showing the  error code:  0xc0000225
    so I used :
    • diskpart (loads the disk partition tool)
    • list volume (show a list of drive volumes)
    • select volume X (where X is the number of the EFI system partition, or ESP). The volume may already be labeled as ESP, or it may just be a small FAT32 partition.
    • assign letter=Z (assigns the volume to a temporary drive).
    • active (marks volume as active)
    • exit (returns to command prompt)
    • bcdboot C:\windows /s Z: /f UEFI (recreate BCD)
    • this did not resolve the issue, it seems worse.
    I have tried all the trouble shooting in windows Recovery Environment (RE), and I am stuck in this loop: auto repair then it goes to: Automatic repair couldn't repair your PC...then the log file: E:\WINDOWS\System32\Logfiles\Srt\SrtTrail.txt
    and then back again to the Windows RE. I have tried to disable driver signature enforcement without luck among other trouble shooting trials. While in command prompt I did the check disk for errors command and it checked drive E  where the operating system (OS) is installed.
    Now I thought prior to this disaster the OS was in C: and not E.
    Also I noticed that my data drives were D  and E. Both  D and E drives have 500 gig capacity  and prior to the system crash D was almost half full and E was empty.
    Now after the system crash and after the all the troubleshooting, including:
    C is now inaccesible
    D is now empty
    E now has the OS
    The log file: E:\WINDOWS\System32\Logfiles\Srt\SrtTrail.txt  generated this notepad log file:
    Startup Repair diagnosis and repair log
    Number of repair attempts: 1
    Session details
    System Disk = \Device\Harddisk1
    Windows directory = E:\WINDOWS
    AutoChk Run = 0
    Number of root causes = 1
    Test Performed:
    Name: Check for updates
    Result: Completed successfully. Error code =  0x0
    Time taken = 0 ms
    Test Performed:
    Name: System disk test
    Time taken = 0 ms
    Test Performed:
    Name: Disk failure diagnosis
    Time taken = 0 ms
    Test Performed:
    Name: Disk metadata test
    Time taken = 0 ms
    Test Performed:
    Name: Target OS test
    Time taken = 47 ms
    Test Performed:
    Name: Volume content check
    Time taken = 47 ms
    Root cause found:
    The operating system version is incompatible with Startup Repair.
    Now i am even more confused. How can I resolve this issue? Please help.
    2016-03-07T18:50:39+00:00
    Hi
    Im still getting the same problems, have attached a copy of the SRT file......HELP Plzzzz What can I do, as I dont want to lose any data. Appreciate any assitance
    Last successful boot time: ‎2/‎21/‎2016 3:23:36 PM (GMT)
    Number of repair attempts: 60
    Session details
    System Disk = \Device\Harddisk0
    AutoChk Run = 0
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 390 ms
    Test Performed:
    Time taken = 32 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Name: Boot manager diagnosis
    Time taken = 78 ms
    Test Performed:
    Name: System boot log diagnosis
    Time taken = 0 ms
    Test Performed:
    Name: Event log diagnosis
    Time taken = 375 ms
    Test Performed:
    Name: Internal state check
    Time taken = 0 ms
    Test Performed:
    Name: Boot status test
    Time taken = 32 ms
    Test Performed:
    Name: Setup state check
    Time taken = 796 ms
    Test Performed:
    Name: Registry hives test
    Time taken = 9063 ms
    Test Performed:
    Name: Windows boot log diagnosis
    Time taken = 0 ms
    Root cause found:
    Boot critical file e:\windows\system32\drivers\windowstrustedrt.sys is corrupt.
    Repair action: File repair
    Result: Failed. Error code =  0x490
    Time taken = 16171 ms
    Repair action: System files integrity check and repair
    Result: Failed. Error code =  0x57
    Time taken = 1381547 ms
    Session details
    AutoChk Run = 0
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 390 ms
    Test Performed:
    Time taken = 47 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 485 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 15 ms
    Test Performed:
    Time taken = 672 ms
    Test Performed:
    Time taken = 63 ms
    Root cause found:
    Startup Repair has tried several times but still cannot determine the cause of the problem.
    Session details
    AutoChk Run = 0
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 406 ms
    Test Performed:
    Time taken = 47 ms
    Test Performed:
    Time taken = 31 ms
    Test Performed:
    Time taken = 469 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 0 ms
    Test Performed:
    Time taken = 641 ms
    Test Performed:
    Time taken = 62 ms
    Root cause found:
