HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2016-01-19T22:28:54+00:00
    I'm having the same message. "failed to transfer logged messages to the event log with status 50"
    Have you been able to solve it?
    2016-01-19T23:25:06+00:00
    I follow these steps, get to that final screen yet when i press any button i still get the Attempting Repairs" dialog followed by the Automatic Repair failure. Any idea?
    2016-01-20T09:46:50+00:00
    Hi. No I am still trying but nothing is working...
