HELP! I've encountered the SrtTrail.txt problem!!!
2013-02-19T09:56:54+00:00
My laptop with Windows 8 Pro 64-bit won't start properly. Every time that I start the laptop up, it tells me that I have a problem and it needs to restart. It then tries to auto-repair the system. I have BitLocker installed on my machine, encrypting my C:, so it asks for the recovery key. When I enter the recovery key it tries to diagnose my PC. After about a minute, I get told that auto-repair couldn't repair my PC, and the file which is causing the problem is C:\Windows\System32\Logfiles\Srt\SrtTrail.txt. I've tried all of the advanced options but they don't seem to be working as after using them it loops. Has anyone got any ideas on how to sort this problem out? The laptop I'm using is a SONY Vaio Duo 11 Ultrabook and I've had i for around 2/3 months.
Windows for home | Other | Search, touch, and mouse
2015-03-31T06:58:09+00:00
I followed the steps to enter the command in the command prompt. When I do I get the following message:
The drive, the path, or the file name is not valid.
I entered the following in the command prompt:
Chkdsk/f/r X:C
any further ideas?
Actually the command is chkdsk /f /r C:      not X:C
2016-08-15T16:39:43+00:00
Root cause found:
Unknown Bugcheck: Bugcheck 3b. Parameters = 0xc0000005, 0xfffff8018302da72, 0xffffd000cb3c8500, 0x0.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff558949%28v=vs.85%29.aspx?f=255&MSPPError=-2147217396
(BING search for
    Bugcheck 3b
<quote>
may occur due to user-mode graphics drivers crossing over and passing bad data to the kernel code.
</quote>
If you can get into the Advanced boot options, try using the Low-res video option.   BTW it helps to have a boot menu to facilitate that.  Otherwise using bootable recovery media may be necessary.
Good luck
Robert Aldwinckle
600+ people found this answer helpful.
112 additional answers
    2015-11-09T13:35:29+00:00
    Hi Greg,
    Thank you for posting your query on Microsoft Community Forums. We are here to assist you in your Windows related issues.
    As per the given issue description, whenever you startup your laptop, you get a message saying that there is a problem with the computer and need to restart and then starts with the Automatic Repair. You have also mentioned that after the diagnosis and repair attempts, it then comes up with a message that Automatic Repair could fix the issue and also it shows that the issue is caused by the file: “C:\Windows\System32\Logfiles\Srt\SrtTrail.txt” which is the log file for the Automatic Repair.
    1.       What all “Advanced Options” have you tried from the Windows Recovery Environment, when the Automatic Repair failed to repair the computer?
    2.       Have you made any recent changes on the computer prior to this issue? If yes, what were they?
    3.        Are you able to boot and log into Windows 8 on your computer now?
    4.       What exactly happen when you boot into the computer? Is it directly going to the Windows Recovery Environment showing the advanced repair options?
    5.       Are you having the Windows 8 Installation CD with you?
    If the computer shows Windows Recovery Environment (Win RE) when you boot, then let’s try running the Check Disk utility using the Command Prompt from the Win RE and check if that helps.
    a)       From the Win RE Screen, click on “Repair your computer” and then select “Troubleshoot”.
    b)       Click on “Advanced options” and click on “Command Prompt”.
    c)       Type the following command in the command prompt window and then press “Enter” key on the keyboard.
    chkdsk /f /r X:( drive letter)
    d)       Press “Y” if you are prompted to perform the Check Disk the next time the computer restarts.
    This would restart the computer and then it will proceed with the Check Disk.
    Important: While performing Error-checking or ChkDsk on the hard drive, if any bad sectors are found and when attempting to repair that sector, the data available on that sector might be lost.
    After the Check Disk is completed, it would restart the computer. After this is completed, I would suggest you to check if the issue persists.
    If the issue persists, then it would be great if you can send me the content of the file “SrtTrail.txt” from the location “C:\Windows\System32\Logfiles\Srt\SrtTrail.txt” You may open this file and then copy and paste its content in your reply. If the Command Prompt shows the current location as “C” drive, then you may access this file by entering the command “cd C:\Windows\System32\Logfiles\Srt\” (enter the command without the quotation mark) and then entering the name “SrtTrail.txt” to open it.
    This will open a notepad with the name “SrtTrail.txt”. Now, you may just include its content when you reply.
    Hope this information helps. If you need any further assistance or information regarding Windows, please feel free to get back to us. We’ll be glad to assist you.
    My Window 10 desktop is refusing to come on. It was upgraded freely from Window 7. The message was C:\Windows\System32\logfiles\Srt\SrtTrail.txt. Below is the content of the file. Kindly assist
    Startup Repair diagnosis and repair log
    Number of repair attempts: 1
    Session details
    System Disk = \Device\Harddisk0
    Windows directory = C:\WINDOWS
    AutoChk Run = 0
    Number of root causes = 1
    Test Performed:
    Name: Check for updates
    Result: Completed successfully. Error code =  0x0
    Time taken = 0 ms
    Test Performed:
    Name: System disk test
    Time taken = 0 ms
    Test Performed:
    Name: Disk failure diagnosis
    Time taken = 47 ms
    Test Performed:
    Name: Disk metadata test
    Time taken = 63 ms
    Test Performed:
    Name: Target OS test
    Time taken = 78 ms
    Test Performed:
    Name: Volume content check
    Time taken = 234 ms
    Root cause found:
    The operating system version is incompatible with Startup Repair
    2015-11-23T18:57:33+00:00
    I Have Asus. I also have backup on external hard drive but it can't find it.  When I do system restore it failed to this C:\Windows\system32\logfiles\srt\SrtTrail.txt. please help. I can't afford a new windows 10 disk.  This is a new computer. My 3rd one in the last 2 month's from Best Buy And they won't help anymore
    2015-11-28T07:05:36+00:00
    Hi!!
    I recommend dont do this step, its just make things worst for me. now i cant even see the recovery options to open chkdsk. the only way for me is to open chkdsk from a windows setup :(.
