How to disable or remove hotkey F1 for Help and support?
2013-02-08T10:55:45+00:00
Hello dear Microsoft team!
 I would like to know, how can I disable hotkey feature (f1) or what file to delete to remove the hotkey feature (opens help and support programm) on my laptop. I am looking foward to hearing from you as soon as possible.
2016-07-30T06:46:53+00:00
For future users coming in off Google, don't listen to these non-helpful responses above.  This is how you do it: for Windows 10 (you can do any one of the three, you do not have to do all of them):
  1. Navigate to C:\Windows, find helppane.exe, right click, Properties, Security tab, Advanced.  On the top where it says "Owner:", hit change.  Type in your username and hit Check Names, click OK.  Apply.  Hit okay back to the Security tab.  Next to "to change permissions, click edit"  hit Edit.  Hit Add, type in your username and click Check Names.  Hit okay and then on the permissions give yourself Full Control with all boxes checked.  Click Apply, yes, then OK.  Ok again to close the box.  Then right click, rename it, hit enter and click Continue to provide administrator permission. to rename it.  Or simply click the file and press Delete on your keyboard to get rid of it.  Now you can press F1 without having to be bothered by the help pane popup!
  2. Open up command prompt, File, run new task, type in regedit and hit enter.  Click yes if there is a popup.
Please backup your registry before making any changes by clicking File > Export (make sure All is selected under Export Range).  Make sure to scroll up and select the uppermost level before searching, for me it is "Computer".  Then Edit > Find.  Under Find What: helppane.exe and make sure only Data is selected and nothing else.  This should lead you to the keys that point towards the executable which you can then rename or remove at your own risk.
  1. Use a program like Sharpkeys (search it online) to disable the F1 button (not recommended as it will disable the button entirely).
1500+ people found this answer helpful.
42 additional answers
    2018-08-11T05:55:50+00:00
    The first step of Bob's post was the answer. Take ownership then delete or rename. THANK GOD. I've ALWAYS hated the help function. The last thing I want EVER is any help function that's built-in to Windows because after 26 years of computing, it's always the inferior choice to a simple Internet search. It's a useless and annoying distraction and a waste of time, just like the average answers here from the Microsoft team who I expect aren't allowed to admit sometimes their tools aren't that good. It's a shame. Microsoft needs to do a much better job of helping people with their products, but maybe wouldn't need to so often if they'd just listen to the customers in the first place.
    2018-08-21T04:27:48+00:00
    im a gamer and some games i play need the f1 key, like gmod i press f1 the menu wont open it will just take me out of game to microsoft edge saying  *how to get help in windows 10* i dont want this feature.
    2018-08-28T18:56:29+00:00
    Disable the F1 Key From your Browser in Windows10
    Open commande prompt with admin and type this in and hit enter:
    @echo off
    taskkill /f /im HelpPane.exe
    takeown /f %WinDir%\HelpPane.exe
    icacls %WinDir%\HelpPane.exe /deny Everyone:(X)
    Wish some people would get the facts be for posting.
    2018-11-19T02:34:42+00:00
    Very simple, I made an AHK script (https://www.autohotkey.com/) that disabled the f1 key. Literally two lines. Their website runs you through how to make one. Just replace the f1 key with something else. You have to keep it running in the background though but it only takes up .5 kb ram.
