How to disable or remove hotkey F1 for Help and support?
2013-02-08T10:55:45+00:00
Hello dear Microsoft team!
 I would like to know, how can I disable hotkey feature (f1) or what file to delete to remove the hotkey feature (opens help and support programm) on my laptop. I am looking foward to hearing from you as soon as possible.
2016-07-30T06:46:53+00:00
For future users coming in off Google, don't listen to these non-helpful responses above.  This is how you do it: for Windows 10 (you can do any one of the three, you do not have to do all of them):
  1. Navigate to C:\Windows, find helppane.exe, right click, Properties, Security tab, Advanced.  On the top where it says "Owner:", hit change.  Type in your username and hit Check Names, click OK.  Apply.  Hit okay back to the Security tab.  Next to "to change permissions, click edit"  hit Edit.  Hit Add, type in your username and click Check Names.  Hit okay and then on the permissions give yourself Full Control with all boxes checked.  Click Apply, yes, then OK.  Ok again to close the box.  Then right click, rename it, hit enter and click Continue to provide administrator permission. to rename it.  Or simply click the file and press Delete on your keyboard to get rid of it.  Now you can press F1 without having to be bothered by the help pane popup!
  2. Open up command prompt, File, run new task, type in regedit and hit enter.  Click yes if there is a popup.
Please backup your registry before making any changes by clicking File > Export (make sure All is selected under Export Range).  Make sure to scroll up and select the uppermost level before searching, for me it is "Computer".  Then Edit > Find.  Under Find What: helppane.exe and make sure only Data is selected and nothing else.  This should lead you to the keys that point towards the executable which you can then rename or remove at your own risk.
  1. Use a program like Sharpkeys (search it online) to disable the F1 button (not recommended as it will disable the button entirely).
1500+ people found this answer helpful.
42 additional answers
    2017-11-28T17:15:14+00:00
    This was super helpful. Didin't work on the first try, and had to first exit Windows Help through the Task Manager, after I renamed it, before I could delete the file.
    2017-12-13T00:10:08+00:00
    Thank you so much, worked like a charm in first try. It's a shame the procedure has to be so convoluted and complex (>20 steps). It also requires fiddling with security settings or regedit both that can easily lead to either unnecessarily lowered security or broken functionality if the wrong values or settings are changed by accident. MS should have provided an easy way to disable helppane instead.
    2017-12-16T19:52:56+00:00
    Hi guys ive tried all but this seemed to work, Thanks to @Ninjameat , this is a way to disable F1 on a keyboard
    @echo off
    taskkill /f /im HelpPane.exe
    takeown /f %WinDir%\HelpPane.exe
    if this does not work i dont know if there is any
    2018-01-23T09:59:37+00:00
    Step 2 didn't work for me, as I was unable to find the right document in Regedit.
    I tried Step 1 last night, but was informed that the program was open and was unable to rename or delete it. I turned my PC off, went to sleep and renamed the file the next morning. This solved my problem. Thank you!
