bsod need help 0x8e
2013-02-18T01:54:30+00:00
I have a lenovo r61i laptop windows xp professional service pack 3 intel pentium dual cpu t2310 @ 1.46ghz x2.  I had this problem before and somehow i fixed it i think i done a bios update this time it dosent work i just get blue screen with following stop code: 0x8e (0xc05, 0x80637f53, 0xa3fd299c,0x0) I have tried my memory modules by taking them out trying one at time and same problem i could get into safe mode with networking but now the networking will not work just safe mode i also tried selective startup and diagnostic startup still bsod used system restore it worked but then when i shut down laptop and went to use it again same thing again. can find loads info on code 8e but dont seem to help so i wrote the full code down as i dont know how to read these codes.  i have no xp cd.  sometimes i can get past bsod and get plain blue screen and get task manager up and i try new task explorer.exe but then bsod again
    2013-02-19T21:52:40+00:00
    If you deleted the driver file I don't see how the driver could cause a bsod. Follow my previous instructions to upload the most recent dump file(s). We may have a different driver causing the issue now.
    2013-02-19T21:59:24+00:00
    cant get into windows normal mode
    2013-02-19T22:47:04+00:00
    for some reason my laptop not got any mini dump files for this year they all last year ill put all the ones i have onto skydrive
    2013-02-20T18:25:23+00:00
    You are correct. I do apologize for not catching that. The dump file you uploaded was dated Oct. 26th, 2012. I cannot believe I didn't catch that.
    When you get the BSOD is there a file listed?
    2013-02-20T21:03:06+00:00
    Just usual writing then the stop code do u want be to post the full code
