527 527 600
t965dm
I have a lenovo r61i laptop windows xp professional service pack 3 intel pentium dual cpu t2310 @ 1.46ghz x2. I had this problem before and somehow i fixed it i think i done a bios update this time it dosent work i just get blue screen with following stop code: 0x8e (0xc05, 0x80637f53, 0xa3fd299c,0x0) I have tried my memory modules by taking them out trying one at time and same problem i could get into safe mode with networking but now the networking will not work just safe mode i also tried selective startup and diagnostic startup still bsod used system restore it worked but then when i shut down laptop and went to use it again same thing again. can find loads info on code 8e but dont seem to help so i wrote the full code down as i dont know how to read these codes. i have no xp cd. sometimes i can get past bsod and get plain blue screen and get task manager up and i try new task explorer.exe but then bsod again
527 527 600
t965dm
the teamviewer closed says trial over
Did you select personal when you installed it?? Is it still crashing then
think i chose personal i try reboot in normal now
no still not work
