Did it go further than before, before it crashed?
This sound like what youre getting now?
Reboot press F1/2 or del (it may tell you) to go into the BIOS. Look for AHCI. Might be under the hard drive entry. Whats on it? enabled or disabled?
I have a lenovo r61i laptop windows xp professional service pack 3 intel pentium dual cpu t2310 @ 1.46ghz x2. I had this problem before and somehow i fixed it i think i done a bios update this time it dosent work i just get blue screen with following stop code: 0x8e (0xc05, 0x80637f53, 0xa3fd299c,0x0) I have tried my memory modules by taking them out trying one at time and same problem i could get into safe mode with networking but now the networking will not work just safe mode i also tried selective startup and diagnostic startup still bsod used system restore it worked but then when i shut down laptop and went to use it again same thing again. can find loads info on code 8e but dont seem to help so i wrote the full code down as i dont know how to read these codes. i have no xp cd. sometimes i can get past bsod and get plain blue screen and get task manager up and i try new task explorer.exe but then bsod again
no further the windows loading sound can be heard but no desktop just blue screen then of to bsod i look bios now
If its the same as what that site says, I would say its a driver or program that you've installed recently
on bios screen i have config,date/time,security,startup,restart,hdd diagnostic program
then names of the system like bios version cpu type etc
in startup the things that show up are boot, network, boot mode(quick),option keys display(enabled),boot device list f12 option (enter),current setting-enabled
under boot the priority is
1: ata hdd0: wdc wd1600bevs-08rst2-(s1)
2: atapi cd0:hl-dt-st dvdram gsa-t20n-(pm)
3: usb cd:
4: usb fdd:
5: pci lan: mba v10.0.9 slot 0400
6: -usb hdd
7: ata hdd1:
8:
excluded from order
ata hdd2
atapi cd1
cant think wat programs i installed recently dont think i installed a driver
