How do I know if my PC has Bluetooth?
2013-07-16T14:42:02+00:00
I have been into Settings and found Wireless, but there is no Bluetooth listed.  Thanks
2013-07-17T06:11:24+00:00
Hi SueLaker,
Thank you for posting your question in Microsoft Community.
Like everything else in your computer, Bluetooth requires both hardware and software. A Bluetooth adapter supplies Bluetooth hardware. If your PC didn’t come with the Bluetooth hardware installed, you can easily add it by purchasing a Bluetooth USB dongle.
. What is the make and model of the computer?
I would suggest you to check the specification of your computer.
To determine whether your PC has Bluetooth hardware, check the Device Manager for Bluetooth Radio by following the steps:
a.    Drag the mouse to bottom left corner and right-click on the ‘Start icon’.
b.    Select ‘Device manager’.
c.    Check for Bluetooth Radio in it or you can also find in Network adapters.
If you need further assistance on this particular issue, let us know and we will be glad to assist you.
1300+ people found this answer helpful.
71 additional answers
  1. Deleted
    2017-08-29T14:37:02+00:00
    Good directions! However, when I went to Device Manager, Network Adapters, there is no Bluetooth. I see that this is an old note, so do I have any other options in 2017?
    2017-08-29T15:14:44+00:00
    Any other options for what? If your computer has no Bluetooth adapter, you'll need to add one.
    2017-09-27T14:41:16+00:00
    Sorry I'm jumping in on the info you supplied to Re MaheshBabu G I have the same type of problem. with a bluetooth dongle. I found it as "radio device" but still I cannot, pair it to the  bluetooth mouse, any idea's it's driving me mad. Thanks
