How do I know if my PC has Bluetooth?
2013-07-16T14:42:02+00:00
I have been into Settings and found Wireless, but there is no Bluetooth listed.  Thanks
2013-07-17T06:11:24+00:00
Hi SueLaker,
Thank you for posting your question in Microsoft Community.
Like everything else in your computer, Bluetooth requires both hardware and software. A Bluetooth adapter supplies Bluetooth hardware. If your PC didn’t come with the Bluetooth hardware installed, you can easily add it by purchasing a Bluetooth USB dongle.
. What is the make and model of the computer?
I would suggest you to check the specification of your computer.
To determine whether your PC has Bluetooth hardware, check the Device Manager for Bluetooth Radio by following the steps:
a.    Drag the mouse to bottom left corner and right-click on the ‘Start icon’.
b.    Select ‘Device manager’.
c.    Check for Bluetooth Radio in it or you can also find in Network adapters.
If you need further assistance on this particular issue, let us know and we will be glad to assist you.
1300+ people found this answer helpful.
71 additional answers
    2016-09-12T22:02:38+00:00
    looking for Bluetooth on my computers  opened network adapters  no Bluetooth listed  need help
    2016-10-02T03:26:07+00:00
    Hi SueLaker,
    Selecting Device Manager then Network Addapters indicates I do not have access to **Bluetooth.**As a Windows 10user what do I need to get my PC have Bluethooth  ?
    James Hart
    2017-01-05T21:16:36+00:00
    My Laptop has bluetooth and I have added a speaker to the devices, however, it won't connect...troubleshooting asks to look for drivers but none are found. How can I link my speaker to the laptop via bluetooth without drivers for the speaker?
    2017-07-23T13:48:20+00:00
    may I know does my pc have Bluetooth connection??
